| 1 | $ VK_LOADER_DEBUG=all flatpak run org.turbowarp.TurboWarp |
| 2 | [2:0516/175907.846180:ERROR:bus.cc(408)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory |
| 3 | [2:0516/175910.185489:ERROR:bus.cc(408)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory |
| 4 | [2:0516/175910.185872:ERROR:bus.cc(408)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory |
| 5 | INFO: Vulkan Loader Version 1.4.307 |
| 6 | WARNING: Vulkan Loader: unsafe searching is enabled |
| 7 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 8 | LAYER: Searching for implicit layer manifest files |
| 9 | LAYER: In following locations: |
| 10 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 11 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 12 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 13 | LAYER: /etc/vulkan/implicit_layer.d |
| 14 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 15 | LAYER: /app/share/vulkan/implicit_layer.d |
| 16 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 17 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 18 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 19 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 20 | LAYER: Found no files |
| 21 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 22 | LAYER: Searching for implicit layer manifest files |
| 23 | LAYER: In following locations: |
| 24 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 25 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 26 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 27 | LAYER: /etc/vulkan/implicit_layer.d |
| 28 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 29 | LAYER: /app/share/vulkan/implicit_layer.d |
| 30 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 31 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 32 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 33 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 34 | LAYER: Found no files |
| 35 | DRIVER: Searching for driver manifest files |
| 36 | DRIVER: In following locations: |
| 37 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/icd.d |
| 38 | DRIVER: /app/etc/xdg/vulkan/icd.d |
| 39 | DRIVER: /etc/xdg/vulkan/icd.d |
| 40 | DRIVER: /etc/vulkan/icd.d |
| 41 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/icd.d |
| 42 | DRIVER: /app/share/vulkan/icd.d |
| 43 | DRIVER: /usr/share/vulkan/icd.d |
| 44 | DRIVER: /usr/share/runtime/share/vulkan/icd.d |
| 45 | DRIVER: /run/host/user-share/vulkan/icd.d |
| 46 | DRIVER: /run/host/share/vulkan/icd.d |
| 47 | DRIVER: Found no files |
| 48 | DRIVER: Searching for driver manifest files |
| 49 | DRIVER: In following locations: |
| 50 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/icd.d |
| 51 | DRIVER: /app/etc/xdg/vulkan/icd.d |
| 52 | DRIVER: /etc/xdg/vulkan/icd.d |
| 53 | DRIVER: /etc/vulkan/icd.d |
| 54 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/icd.d |
| 55 | DRIVER: /app/share/vulkan/icd.d |
| 56 | DRIVER: /usr/share/vulkan/icd.d |
| 57 | DRIVER: /usr/share/runtime/share/vulkan/icd.d |
| 58 | DRIVER: /run/host/user-share/vulkan/icd.d |
| 59 | DRIVER: /run/host/share/vulkan/icd.d |
| 60 | DRIVER: Found no files |
| 61 | LAYER: Searching for implicit layer manifest files |
| 62 | LAYER: In following locations: |
| 63 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 64 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 65 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 66 | LAYER: /etc/vulkan/implicit_layer.d |
| 67 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 68 | LAYER: /app/share/vulkan/implicit_layer.d |
| 69 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 70 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 71 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 72 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 73 | LAYER: Found no files |
| 74 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 75 | LAYER: Searching for implicit layer manifest files |
| 76 | LAYER: In following locations: |
| 77 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 78 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 79 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 80 | LAYER: /etc/vulkan/implicit_layer.d |
| 81 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 82 | LAYER: /app/share/vulkan/implicit_layer.d |
| 83 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 84 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 85 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 86 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 87 | LAYER: Found no files |
| 88 | DRIVER: Searching for driver manifest files |
| 89 | DRIVER: In following locations: |
| 90 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/icd.d |
| 91 | DRIVER: /app/etc/xdg/vulkan/icd.d |
| 92 | DRIVER: /etc/xdg/vulkan/icd.d |
| 93 | DRIVER: /etc/vulkan/icd.d |
| 94 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/icd.d |
| 95 | DRIVER: /app/share/vulkan/icd.d |
| 96 | DRIVER: /usr/share/vulkan/icd.d |
| 97 | DRIVER: /usr/share/runtime/share/vulkan/icd.d |
| 98 | DRIVER: /run/host/user-share/vulkan/icd.d |
| 99 | DRIVER: /run/host/share/vulkan/icd.d |
| 100 | DRIVER: Found no files |
| 101 | LAYER: Searching for implicit layer manifest files |
| 102 | LAYER: In following locations: |
| 103 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 104 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 105 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 106 | LAYER: /etc/vulkan/implicit_layer.d |
| 107 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 108 | LAYER: /app/share/vulkan/implicit_layer.d |
| 109 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 110 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 111 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 112 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 113 | LAYER: Found no files |
| 114 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 115 | LAYER: Searching for implicit layer manifest files |
| 116 | LAYER: In following locations: |
| 117 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 118 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 119 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 120 | LAYER: /etc/vulkan/implicit_layer.d |
| 121 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 122 | LAYER: /app/share/vulkan/implicit_layer.d |
| 123 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 124 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 125 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 126 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 127 | LAYER: Found no files |
| 128 | LAYER: Searching for explicit layer manifest files |
| 129 | LAYER: In following locations: |
| 130 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/explicit_layer.d |
| 131 | LAYER: /app/etc/xdg/vulkan/explicit_layer.d |
| 132 | LAYER: /etc/xdg/vulkan/explicit_layer.d |
| 133 | LAYER: /etc/vulkan/explicit_layer.d |
| 134 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/explicit_layer.d |
| 135 | LAYER: /app/share/vulkan/explicit_layer.d |
| 136 | LAYER: /usr/share/vulkan/explicit_layer.d |
| 137 | LAYER: /usr/share/runtime/share/vulkan/explicit_layer.d |
| 138 | LAYER: /run/host/user-share/vulkan/explicit_layer.d |
| 139 | LAYER: /run/host/share/vulkan/explicit_layer.d |
| 140 | LAYER: Found no files |
| 141 | DRIVER: Searching for driver manifest files |
| 142 | DRIVER: In following locations: |
| 143 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/icd.d |
| 144 | DRIVER: /app/etc/xdg/vulkan/icd.d |
| 145 | DRIVER: /etc/xdg/vulkan/icd.d |
| 146 | DRIVER: /etc/vulkan/icd.d |
| 147 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/icd.d |
| 148 | DRIVER: /app/share/vulkan/icd.d |
| 149 | DRIVER: /usr/share/vulkan/icd.d |
| 150 | DRIVER: /usr/share/runtime/share/vulkan/icd.d |
| 151 | DRIVER: /run/host/user-share/vulkan/icd.d |
| 152 | DRIVER: /run/host/share/vulkan/icd.d |
| 153 | DRIVER: Found no files |
| 154 | ERROR | DRIVER: vkCreateInstance: Found no drivers! |
| 155 | INFO: Vulkan Loader Version 1.4.307 |
| 156 | WARNING: Vulkan Loader: unsafe searching is enabled |
| 157 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 158 | LAYER: Searching for implicit layer manifest files |
| 159 | LAYER: In following locations: |
| 160 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 161 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 162 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 163 | LAYER: /etc/vulkan/implicit_layer.d |
| 164 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 165 | LAYER: /app/share/vulkan/implicit_layer.d |
| 166 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 167 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 168 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 169 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 170 | LAYER: Found no files |
| 171 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 172 | LAYER: Searching for implicit layer manifest files |
| 173 | LAYER: In following locations: |
| 174 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 175 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 176 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 177 | LAYER: /etc/vulkan/implicit_layer.d |
| 178 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 179 | LAYER: /app/share/vulkan/implicit_layer.d |
| 180 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 181 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 182 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 183 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 184 | LAYER: Found no files |
| 185 | DRIVER: Searching for driver manifest files |
| 186 | DRIVER: In following locations: |
| 187 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/icd.d |
| 188 | DRIVER: /app/etc/xdg/vulkan/icd.d |
| 189 | DRIVER: /etc/xdg/vulkan/icd.d |
| 190 | DRIVER: /etc/vulkan/icd.d |
| 191 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/icd.d |
| 192 | DRIVER: /app/share/vulkan/icd.d |
| 193 | DRIVER: /usr/share/vulkan/icd.d |
| 194 | DRIVER: /usr/share/runtime/share/vulkan/icd.d |
| 195 | DRIVER: /run/host/user-share/vulkan/icd.d |
| 196 | DRIVER: /run/host/share/vulkan/icd.d |
| 197 | DRIVER: Found no files |
| 198 | DRIVER: Searching for driver manifest files |
| 199 | DRIVER: In following locations: |
| 200 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/icd.d |
| 201 | DRIVER: /app/etc/xdg/vulkan/icd.d |
| 202 | DRIVER: /etc/xdg/vulkan/icd.d |
| 203 | DRIVER: /etc/vulkan/icd.d |
| 204 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/icd.d |
| 205 | DRIVER: /app/share/vulkan/icd.d |
| 206 | DRIVER: /usr/share/vulkan/icd.d |
| 207 | DRIVER: /usr/share/runtime/share/vulkan/icd.d |
| 208 | DRIVER: /run/host/user-share/vulkan/icd.d |
| 209 | DRIVER: /run/host/share/vulkan/icd.d |
| 210 | DRIVER: Found no files |
| 211 | LAYER: Searching for implicit layer manifest files |
| 212 | LAYER: In following locations: |
| 213 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 214 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 215 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 216 | LAYER: /etc/vulkan/implicit_layer.d |
| 217 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 218 | LAYER: /app/share/vulkan/implicit_layer.d |
| 219 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 220 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 221 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 222 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 223 | LAYER: Found no files |
| 224 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 225 | LAYER: Searching for implicit layer manifest files |
| 226 | LAYER: In following locations: |
| 227 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 228 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 229 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 230 | LAYER: /etc/vulkan/implicit_layer.d |
| 231 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 232 | LAYER: /app/share/vulkan/implicit_layer.d |
| 233 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 234 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 235 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 236 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 237 | LAYER: Found no files |
| 238 | DRIVER: Searching for driver manifest files |
| 239 | DRIVER: In following locations: |
| 240 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/icd.d |
| 241 | DRIVER: /app/etc/xdg/vulkan/icd.d |
| 242 | DRIVER: /etc/xdg/vulkan/icd.d |
| 243 | DRIVER: /etc/vulkan/icd.d |
| 244 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/icd.d |
| 245 | DRIVER: /app/share/vulkan/icd.d |
| 246 | DRIVER: /usr/share/vulkan/icd.d |
| 247 | DRIVER: /usr/share/runtime/share/vulkan/icd.d |
| 248 | DRIVER: /run/host/user-share/vulkan/icd.d |
| 249 | DRIVER: /run/host/share/vulkan/icd.d |
| 250 | DRIVER: Found no files |
| 251 | LAYER: Searching for implicit layer manifest files |
| 252 | LAYER: In following locations: |
| 253 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 254 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 255 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 256 | LAYER: /etc/vulkan/implicit_layer.d |
| 257 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 258 | LAYER: /app/share/vulkan/implicit_layer.d |
| 259 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 260 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 261 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 262 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 263 | LAYER: Found no files |
| 264 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 265 | LAYER: Searching for implicit layer manifest files |
| 266 | LAYER: In following locations: |
| 267 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 268 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 269 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 270 | LAYER: /etc/vulkan/implicit_layer.d |
| 271 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 272 | LAYER: /app/share/vulkan/implicit_layer.d |
| 273 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 274 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 275 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 276 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 277 | LAYER: Found no files |
| 278 | LAYER: Searching for implicit layer manifest files |
| 279 | LAYER: In following locations: |
| 280 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 281 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 282 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 283 | LAYER: /etc/vulkan/implicit_layer.d |
| 284 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 285 | LAYER: /app/share/vulkan/implicit_layer.d |
| 286 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 287 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 288 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 289 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 290 | LAYER: Found no files |
| 291 | LAYER: Searching for explicit layer manifest files |
| 292 | LAYER: In following locations: |
| 293 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/explicit_layer.d |
| 294 | LAYER: /app/etc/xdg/vulkan/explicit_layer.d |
| 295 | LAYER: /etc/xdg/vulkan/explicit_layer.d |
| 296 | LAYER: /etc/vulkan/explicit_layer.d |
| 297 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/explicit_layer.d |
| 298 | LAYER: /app/share/vulkan/explicit_layer.d |
| 299 | LAYER: /usr/share/vulkan/explicit_layer.d |
| 300 | LAYER: /usr/share/runtime/share/vulkan/explicit_layer.d |
| 301 | LAYER: /run/host/user-share/vulkan/explicit_layer.d |
| 302 | LAYER: /run/host/share/vulkan/explicit_layer.d |
| 303 | LAYER: Found no files |
| 304 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 305 | LAYER: Searching for implicit layer manifest files |
| 306 | LAYER: In following locations: |
| 307 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 308 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 309 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 310 | LAYER: /etc/vulkan/implicit_layer.d |
| 311 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 312 | LAYER: /app/share/vulkan/implicit_layer.d |
| 313 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 314 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 315 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 316 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 317 | LAYER: Found no files |
| 318 | LAYER: Searching for implicit layer manifest files |
| 319 | LAYER: In following locations: |
| 320 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 321 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 322 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 323 | LAYER: /etc/vulkan/implicit_layer.d |
| 324 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 325 | LAYER: /app/share/vulkan/implicit_layer.d |
| 326 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 327 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 328 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 329 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 330 | LAYER: Found no files |
| 331 | LAYER: Searching for explicit layer manifest files |
| 332 | LAYER: In following locations: |
| 333 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/explicit_layer.d |
| 334 | LAYER: /app/etc/xdg/vulkan/explicit_layer.d |
| 335 | LAYER: /etc/xdg/vulkan/explicit_layer.d |
| 336 | LAYER: /etc/vulkan/explicit_layer.d |
| 337 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/explicit_layer.d |
| 338 | LAYER: /app/share/vulkan/explicit_layer.d |
| 339 | LAYER: /usr/share/vulkan/explicit_layer.d |
| 340 | LAYER: /usr/share/runtime/share/vulkan/explicit_layer.d |
| 341 | LAYER: /run/host/user-share/vulkan/explicit_layer.d |
| 342 | LAYER: /run/host/share/vulkan/explicit_layer.d |
| 343 | LAYER: Found no files |
| 344 | INFO: No valid vk_loader_settings.json file found, no loader settings will be active |
| 345 | LAYER: Searching for implicit layer manifest files |
| 346 | LAYER: In following locations: |
| 347 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/implicit_layer.d |
| 348 | LAYER: /app/etc/xdg/vulkan/implicit_layer.d |
| 349 | LAYER: /etc/xdg/vulkan/implicit_layer.d |
| 350 | LAYER: /etc/vulkan/implicit_layer.d |
| 351 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/implicit_layer.d |
| 352 | LAYER: /app/share/vulkan/implicit_layer.d |
| 353 | LAYER: /usr/share/vulkan/implicit_layer.d |
| 354 | LAYER: /usr/share/runtime/share/vulkan/implicit_layer.d |
| 355 | LAYER: /run/host/user-share/vulkan/implicit_layer.d |
| 356 | LAYER: /run/host/share/vulkan/implicit_layer.d |
| 357 | LAYER: Found no files |
| 358 | LAYER: Searching for explicit layer manifest files |
| 359 | LAYER: In following locations: |
| 360 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/explicit_layer.d |
| 361 | LAYER: /app/etc/xdg/vulkan/explicit_layer.d |
| 362 | LAYER: /etc/xdg/vulkan/explicit_layer.d |
| 363 | LAYER: /etc/vulkan/explicit_layer.d |
| 364 | LAYER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/explicit_layer.d |
| 365 | LAYER: /app/share/vulkan/explicit_layer.d |
| 366 | LAYER: /usr/share/vulkan/explicit_layer.d |
| 367 | LAYER: /usr/share/runtime/share/vulkan/explicit_layer.d |
| 368 | LAYER: /run/host/user-share/vulkan/explicit_layer.d |
| 369 | LAYER: /run/host/share/vulkan/explicit_layer.d |
| 370 | LAYER: Found no files |
| 371 | DRIVER: Searching for driver manifest files |
| 372 | DRIVER: In following locations: |
| 373 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/config/vulkan/icd.d |
| 374 | DRIVER: /app/etc/xdg/vulkan/icd.d |
| 375 | DRIVER: /etc/xdg/vulkan/icd.d |
| 376 | DRIVER: /etc/vulkan/icd.d |
| 377 | DRIVER: /home/swee/.var/app/org.turbowarp.TurboWarp/data/vulkan/icd.d |
| 378 | DRIVER: /app/share/vulkan/icd.d |
| 379 | DRIVER: /usr/share/vulkan/icd.d |
| 380 | DRIVER: /usr/share/runtime/share/vulkan/icd.d |
| 381 | DRIVER: /run/host/user-share/vulkan/icd.d |
| 382 | DRIVER: /run/host/share/vulkan/icd.d |
| 383 | DRIVER: Found no files |
| 384 | ERROR | DRIVER: vkCreateInstance: Found no drivers! |
| 385 | MESA: error: ZINK: vkCreateInstance failed (VK_ERROR_INCOMPATIBLE_DRIVER) |
| 386 |
swee / gist:c8093f64755a42f0aa68666afa8a5a8b
