| 1 | $ sudo pkg upgrade |
| 2 | Updating FreeBSD repository catalogue... |
| 3 | FreeBSD repository is up to date. |
| 4 | Updating FreeBSD-kmods repository catalogue... |
| 5 | FreeBSD-kmods repository is up to date. |
| 6 | Updating FreeBSD-base repository catalogue... |
| 7 | FreeBSD-base repository is up to date. |
| 8 | All repositories are up to date. |
| 9 | Checking for upgrades (321 candidates): 100% |
| 10 | Processing candidates (321 candidates): 100% |
| 11 | Checking integrity... done (4 conflicting) |
| 12 | - drm-612-kmod-6.12.110.1501000_3 [FreeBSD] conflicts with drm-66-kmod-6.6.25.1501000_9 [installed] on /boot/modules/amdgpu.ko |
| 13 | - drm-612-kmod-6.12.110.1501000_3 [FreeBSD] conflicts with drm-66-kmod-6.6.25.1501000_11 [FreeBSD-kmods] on /boot/modules/amdgpu.ko |
| 14 | - luajit-openresty-2.1.20250826_1 [FreeBSD] conflicts with luajit-2.1.0.20260903 [installed] on /usr/local/bin/luajit |
| 15 | - luajit-openresty-2.1.20250826_1 [FreeBSD] conflicts with luajit-2.1.0.20260908 [FreeBSD] on /usr/local/bin/luajit |
| 16 | Cannot solve problem using SAT solver, trying another plan |
| 17 | Cannot solve problem using SAT solver, trying another plan |
| 18 | Cannot solve problem using SAT solver, trying another plan |
| 19 | Checking integrity... done (0 conflicting) |
| 20 | The following 335 package(s) will be affected (of 0 checked): |
| 21 | |
| 22 | New packages to be INSTALLED: |
| 23 | csound: 6.15.0_11 [FreeBSD] |
| 24 | drm-612-kmod: 6.12.110.1501000_3 [FreeBSD] |
| 25 | dssi: 1.1.1_13 [FreeBSD] |
| 26 | faust: 2.88.0 [FreeBSD] |
| 27 | gstreamer1-plugins-dtls: 1.28.6 [FreeBSD] |
| 28 | gstreamer1-plugins-rust: 1.28.6_1 [FreeBSD] |
| 29 | gstreamer1-plugins-sctp: 1.28.6 [FreeBSD] |
| 30 | gstreamer1-plugins-srtp: 1.28.6 [FreeBSD] |
| 31 | gstreamer1-plugins-webrtc: 1.28.6 [FreeBSD] |
| 32 | libdssialsacompat: 1.0.8a_2 [FreeBSD] |
| 33 | liblo: 0.36 [FreeBSD] |
| 34 | luajit-openresty: 2.1.20250826_1 [FreeBSD] |
| 35 | py312-pysequoia: 0.1.35 [FreeBSD] |
| 36 | stk: 5.0.1 [FreeBSD] |
| 37 | vvdec: 3.2.0 [FreeBSD] |
| 38 | |
| 39 | Installed packages to be UPGRADED: |
| 40 | AppStream: 1.2.0 -> 1.2.1 [FreeBSD] |
| 41 | FreeBSD-acct: 15.1 -> 15.1p4 [FreeBSD-base] |
| 42 | FreeBSD-audit: 15.1p2 -> 15.1p4 [FreeBSD-base] |
| 43 | FreeBSD-bhyve: 15.1p2 -> 15.1p4 [FreeBSD-base] |
| 44 | FreeBSD-clibs: 15.1p2 -> 15.1p4 [FreeBSD-base] |
| 45 | FreeBSD-clibs-dev: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 46 | FreeBSD-clibs-dev-lib32: 15.1p2 -> 15.1p4 [FreeBSD-base] |
| 47 | FreeBSD-clibs-lib32: 15.1p2 -> 15.1p4 [FreeBSD-base] |
| 48 | FreeBSD-ctl: 15.1p2 -> 15.1p4 [FreeBSD-base] |
| 49 | FreeBSD-dhclient: 15.1 -> 15.1p4 [FreeBSD-base] |
| 50 | FreeBSD-dma: 15.1 -> 15.1p4 [FreeBSD-base] |
| 51 | FreeBSD-games: 15.1 -> 15.1p4 [FreeBSD-base] |
| 52 | FreeBSD-hast: 15.1 -> 15.1p4 [FreeBSD-base] |
| 53 | FreeBSD-iscsi: 15.1 -> 15.1p4 [FreeBSD-base] |
| 54 | FreeBSD-kernel-generic: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 55 | FreeBSD-kernel-generic-dbg: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 56 | FreeBSD-kernel-man: 15.1 -> 15.1p4 [FreeBSD-base] |
| 57 | FreeBSD-libcasper: 15.1 -> 15.1p4 [FreeBSD-base] |
| 58 | FreeBSD-libcasper-lib32: 15.1 -> 15.1p4 [FreeBSD-base] |
| 59 | FreeBSD-libvmmapi: 15.1 -> 15.1p4 [FreeBSD-base] |
| 60 | FreeBSD-libvmmapi-dev: 15.1 -> 15.1p4 [FreeBSD-base] |
| 61 | FreeBSD-openssl-dev: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 62 | FreeBSD-openssl-dev-lib32: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 63 | FreeBSD-openssl-lib: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 64 | FreeBSD-openssl-lib32: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 65 | FreeBSD-rcmds: 15.1 -> 15.1p4 [FreeBSD-base] |
| 66 | FreeBSD-rescue: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 67 | FreeBSD-runtime: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 68 | FreeBSD-runtime-dev: 15.1p1 -> 15.1p4 [FreeBSD-base] |
| 69 | FreeBSD-runtime-dev-lib32: 15.1p1 -> 15.1p4 [FreeBSD-base] |
| 70 | FreeBSD-runtime-lib32: 15.1p1 -> 15.1p4 [FreeBSD-base] |
| 71 | FreeBSD-sound: 15.1 -> 15.1p4 [FreeBSD-base] |
| 72 | FreeBSD-ssh: 15.1 -> 15.1p4 [FreeBSD-base] |
| 73 | FreeBSD-syslogd: 15.1p2 -> 15.1p4 [FreeBSD-base] |
| 74 | FreeBSD-tests: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 75 | FreeBSD-tests-dbg: 15.1p3 -> 15.1p4 [FreeBSD-base] |
| 76 | FreeBSD-toolchain: 15.1 -> 15.1p4 [FreeBSD-base] |
| 77 | FreeBSD-utilities: 15.1p2 -> 15.1p4 [FreeBSD-base] |
| 78 | FreeBSD-utilities-dev: 15.1p1 -> 15.1p4 [FreeBSD-base] |
| 79 | FreeBSD-utilities-dev-lib32: 15.1p1 -> 15.1p4 [FreeBSD-base] |
| 80 | FreeBSD-utilities-lib32: 15.1p1 -> 15.1p4 [FreeBSD-base] |
| 81 | FreeBSD-xz: 15.1 -> 15.1p4 [FreeBSD-base] |
| 82 | FreeBSD-zoneinfo: 15.1p2 -> 15.1p4 [FreeBSD-base] |
| 83 | Imath: 3.2.3 -> 3.2.3_1 [FreeBSD] |
| 84 | asciinema: 3.2.1_2 -> 3.2.1_3 [FreeBSD] |
| 85 | boost-libs: 1.91.0 -> 1.92.0 [FreeBSD] |
| 86 | ca_root_nss: 3.129 -> 3.131 [FreeBSD] |
| 87 | chromium: 152.0.7977.75_2 -> 154.0.8037.57 [FreeBSD] |
| 88 | drm-66-kmod: 6.6.25.1501000_9 -> 6.6.25.1501000_11 [FreeBSD] |
| 89 | expat: 2.8.4 -> 2.8.5 [FreeBSD] |
| 90 | fastfetch: 2.68.1 -> 2.69.0 [FreeBSD] |
| 91 | ffmpeg: 9.0.1,1 -> 9.0.2_1,1 [FreeBSD] |
| 92 | fribidi: 1.0.16 -> 1.0.17 [FreeBSD] |
| 93 | gajim: 2.4.6 -> 2.6.0_1 [FreeBSD] |
| 94 | gdb: 15.1_6 -> 15.1_7 [FreeBSD] |
| 95 | git: 2.55.0 -> 2.56.0 [FreeBSD] |
| 96 | gohugo: 0.165.0_3,1 -> 0.167.0,1 [FreeBSD] |
| 97 | gpu-firmware-amd-kmod-aldebaran: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 98 | gpu-firmware-amd-kmod-aldebaran-ip-discovery: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 99 | gpu-firmware-amd-kmod-arcturus: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 100 | gpu-firmware-amd-kmod-arcturus-ip-discovery: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 101 | gpu-firmware-amd-kmod-banks: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 102 | gpu-firmware-amd-kmod-beige-goby: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 103 | gpu-firmware-amd-kmod-bonaire: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 104 | gpu-firmware-amd-kmod-carrizo: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 105 | gpu-firmware-amd-kmod-cyan-skillfish2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 106 | gpu-firmware-amd-kmod-dcn-3-1-4: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 107 | gpu-firmware-amd-kmod-dcn-3-1-5: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 108 | gpu-firmware-amd-kmod-dcn-3-1-6: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 109 | gpu-firmware-amd-kmod-dcn-3-2-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 110 | gpu-firmware-amd-kmod-dcn-3-2-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 111 | gpu-firmware-amd-kmod-dcn-3-5: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 112 | gpu-firmware-amd-kmod-dcn-3-5-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 113 | gpu-firmware-amd-kmod-dcn-3-6: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 114 | gpu-firmware-amd-kmod-dcn-4-0-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 115 | gpu-firmware-amd-kmod-dimgrey-cavefish: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 116 | gpu-firmware-amd-kmod-fiji: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 117 | gpu-firmware-amd-kmod-gc-10-3-6: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 118 | gpu-firmware-amd-kmod-gc-10-3-7: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 119 | gpu-firmware-amd-kmod-gc-11-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 120 | gpu-firmware-amd-kmod-gc-11-0-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 121 | gpu-firmware-amd-kmod-gc-11-0-2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 122 | gpu-firmware-amd-kmod-gc-11-0-3: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 123 | gpu-firmware-amd-kmod-gc-11-0-4: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 124 | gpu-firmware-amd-kmod-gc-11-5-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 125 | gpu-firmware-amd-kmod-gc-11-5-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 126 | gpu-firmware-amd-kmod-gc-11-5-2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 127 | gpu-firmware-amd-kmod-gc-11-5-3: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 128 | gpu-firmware-amd-kmod-gc-12-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 129 | gpu-firmware-amd-kmod-gc-12-0-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 130 | gpu-firmware-amd-kmod-gc-9-4-3: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 131 | gpu-firmware-amd-kmod-gc-9-4-4: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 132 | gpu-firmware-amd-kmod-gc-9-5-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 133 | gpu-firmware-amd-kmod-green-sardine: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 134 | gpu-firmware-amd-kmod-hainan: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 135 | gpu-firmware-amd-kmod-hawaii: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 136 | gpu-firmware-amd-kmod-isp-4-1-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 137 | gpu-firmware-amd-kmod-kabini: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 138 | gpu-firmware-amd-kmod-kaveri: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 139 | gpu-firmware-amd-kmod-mullins: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 140 | gpu-firmware-amd-kmod-navi10: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 141 | gpu-firmware-amd-kmod-navi12: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 142 | gpu-firmware-amd-kmod-navi14: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 143 | gpu-firmware-amd-kmod-navy-flounder: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 144 | gpu-firmware-amd-kmod-oland: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 145 | gpu-firmware-amd-kmod-picasso: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 146 | gpu-firmware-amd-kmod-picasso-ip-discovery: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 147 | gpu-firmware-amd-kmod-pitcairn: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 148 | gpu-firmware-amd-kmod-polaris10: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 149 | gpu-firmware-amd-kmod-polaris11: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 150 | gpu-firmware-amd-kmod-polaris12: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 151 | gpu-firmware-amd-kmod-psp-13-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 152 | gpu-firmware-amd-kmod-psp-13-0-10: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 153 | gpu-firmware-amd-kmod-psp-13-0-11: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 154 | gpu-firmware-amd-kmod-psp-13-0-12: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 155 | gpu-firmware-amd-kmod-psp-13-0-14: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 156 | gpu-firmware-amd-kmod-psp-13-0-4: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 157 | gpu-firmware-amd-kmod-psp-13-0-5: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 158 | gpu-firmware-amd-kmod-psp-13-0-6: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 159 | gpu-firmware-amd-kmod-psp-13-0-7: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 160 | gpu-firmware-amd-kmod-psp-13-0-8: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 161 | gpu-firmware-amd-kmod-psp-14-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 162 | gpu-firmware-amd-kmod-psp-14-0-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 163 | gpu-firmware-amd-kmod-psp-14-0-2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 164 | gpu-firmware-amd-kmod-psp-14-0-3: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 165 | gpu-firmware-amd-kmod-psp-14-0-4: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 166 | gpu-firmware-amd-kmod-psp-14-0-5: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 167 | gpu-firmware-amd-kmod-raven: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 168 | gpu-firmware-amd-kmod-raven-ip-discovery: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 169 | gpu-firmware-amd-kmod-raven2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 170 | gpu-firmware-amd-kmod-raven2-ip-discovery: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 171 | gpu-firmware-amd-kmod-renoir: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 172 | gpu-firmware-amd-kmod-sdma-4-4-2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 173 | gpu-firmware-amd-kmod-sdma-4-4-4: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 174 | gpu-firmware-amd-kmod-sdma-4-4-5: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 175 | gpu-firmware-amd-kmod-sdma-5-2-6: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 176 | gpu-firmware-amd-kmod-sdma-5-2-7: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 177 | gpu-firmware-amd-kmod-sdma-6-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 178 | gpu-firmware-amd-kmod-sdma-6-0-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 179 | gpu-firmware-amd-kmod-sdma-6-0-2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 180 | gpu-firmware-amd-kmod-sdma-6-0-3: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 181 | gpu-firmware-amd-kmod-sdma-6-1-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 182 | gpu-firmware-amd-kmod-sdma-6-1-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 183 | gpu-firmware-amd-kmod-sdma-6-1-2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 184 | gpu-firmware-amd-kmod-sdma-6-1-3: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 185 | gpu-firmware-amd-kmod-sdma-7-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 186 | gpu-firmware-amd-kmod-sdma-7-0-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 187 | gpu-firmware-amd-kmod-si58: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 188 | gpu-firmware-amd-kmod-sienna-cichlid: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 189 | gpu-firmware-amd-kmod-smu-13-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 190 | gpu-firmware-amd-kmod-smu-13-0-10: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 191 | gpu-firmware-amd-kmod-smu-13-0-14: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 192 | gpu-firmware-amd-kmod-smu-13-0-6: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 193 | gpu-firmware-amd-kmod-smu-13-0-7: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 194 | gpu-firmware-amd-kmod-smu-14-0-2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 195 | gpu-firmware-amd-kmod-smu-14-0-3: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 196 | gpu-firmware-amd-kmod-stoney: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 197 | gpu-firmware-amd-kmod-tahiti: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 198 | gpu-firmware-amd-kmod-tonga: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 199 | gpu-firmware-amd-kmod-topaz: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 200 | gpu-firmware-amd-kmod-umsch-mm-4-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 201 | gpu-firmware-amd-kmod-vangogh: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 202 | gpu-firmware-amd-kmod-vcn-3-1-2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 203 | gpu-firmware-amd-kmod-vcn-4-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 204 | gpu-firmware-amd-kmod-vcn-4-0-2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 205 | gpu-firmware-amd-kmod-vcn-4-0-3: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 206 | gpu-firmware-amd-kmod-vcn-4-0-4: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 207 | gpu-firmware-amd-kmod-vcn-4-0-5: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 208 | gpu-firmware-amd-kmod-vcn-4-0-6: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 209 | gpu-firmware-amd-kmod-vcn-4-0-6-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 210 | gpu-firmware-amd-kmod-vcn-5-0-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 211 | gpu-firmware-amd-kmod-vcn-5-0-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 212 | gpu-firmware-amd-kmod-vega10: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 213 | gpu-firmware-amd-kmod-vega10-ip-discovery: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 214 | gpu-firmware-amd-kmod-vega12: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 215 | gpu-firmware-amd-kmod-vega12-ip-discovery: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 216 | gpu-firmware-amd-kmod-vega20: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 217 | gpu-firmware-amd-kmod-vega20-ip-discovery: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 218 | gpu-firmware-amd-kmod-vegam: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 219 | gpu-firmware-amd-kmod-verde: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 220 | gpu-firmware-amd-kmod-vpe-6-1-0: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 221 | gpu-firmware-amd-kmod-vpe-6-1-1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 222 | gpu-firmware-amd-kmod-vpe-6-1-3: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 223 | gpu-firmware-amd-kmod-yellow-carp: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 224 | gpu-firmware-intel-kmod-alderlake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 225 | gpu-firmware-intel-kmod-battlemage: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 226 | gpu-firmware-intel-kmod-broxton: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 227 | gpu-firmware-intel-kmod-cannonlake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 228 | gpu-firmware-intel-kmod-dg1: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 229 | gpu-firmware-intel-kmod-dg2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 230 | gpu-firmware-intel-kmod-elkhartlake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 231 | gpu-firmware-intel-kmod-geminilake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 232 | gpu-firmware-intel-kmod-icelake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 233 | gpu-firmware-intel-kmod-kabylake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 234 | gpu-firmware-intel-kmod-meteorlake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 235 | gpu-firmware-intel-kmod-rocketlake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 236 | gpu-firmware-intel-kmod-skylake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 237 | gpu-firmware-intel-kmod-tigerlake: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 238 | gpu-firmware-radeon-kmod-aruba: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 239 | gpu-firmware-radeon-kmod-barts: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 240 | gpu-firmware-radeon-kmod-bonaire: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 241 | gpu-firmware-radeon-kmod-btc: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 242 | gpu-firmware-radeon-kmod-caicos: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 243 | gpu-firmware-radeon-kmod-cayman: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 244 | gpu-firmware-radeon-kmod-cedar: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 245 | gpu-firmware-radeon-kmod-cypress: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 246 | gpu-firmware-radeon-kmod-hainan: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 247 | gpu-firmware-radeon-kmod-hawaii: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 248 | gpu-firmware-radeon-kmod-juniper: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 249 | gpu-firmware-radeon-kmod-kabini: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 250 | gpu-firmware-radeon-kmod-kaveri: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 251 | gpu-firmware-radeon-kmod-mullins: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 252 | gpu-firmware-radeon-kmod-oland: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 253 | gpu-firmware-radeon-kmod-palm: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 254 | gpu-firmware-radeon-kmod-pitcairn: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 255 | gpu-firmware-radeon-kmod-r100: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 256 | gpu-firmware-radeon-kmod-r200: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 257 | gpu-firmware-radeon-kmod-r300: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 258 | gpu-firmware-radeon-kmod-r420: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 259 | gpu-firmware-radeon-kmod-r520: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 260 | gpu-firmware-radeon-kmod-r600: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 261 | gpu-firmware-radeon-kmod-r700: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 262 | gpu-firmware-radeon-kmod-redwood: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 263 | gpu-firmware-radeon-kmod-rs600: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 264 | gpu-firmware-radeon-kmod-rs690: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 265 | gpu-firmware-radeon-kmod-rs780: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 266 | gpu-firmware-radeon-kmod-rv610: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 267 | gpu-firmware-radeon-kmod-rv620: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 268 | gpu-firmware-radeon-kmod-rv630: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 269 | gpu-firmware-radeon-kmod-rv635: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 270 | gpu-firmware-radeon-kmod-rv670: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 271 | gpu-firmware-radeon-kmod-rv710: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 272 | gpu-firmware-radeon-kmod-rv730: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 273 | gpu-firmware-radeon-kmod-rv740: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 274 | gpu-firmware-radeon-kmod-rv770: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 275 | gpu-firmware-radeon-kmod-sumo: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 276 | gpu-firmware-radeon-kmod-sumo2: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 277 | gpu-firmware-radeon-kmod-tahiti: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 278 | gpu-firmware-radeon-kmod-turks: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 279 | gpu-firmware-radeon-kmod-verde: 20260519.1500068 -> 20260519.1501000 [FreeBSD] |
| 280 | groff: 1.24.1_1 -> 1.24.2 [FreeBSD] |
| 281 | gumbo: 0.14.0 -> 0.14.1 [FreeBSD] |
| 282 | inkscape: 1.4.4_1 -> 1.4.4_2 [FreeBSD] |
| 283 | kirigami-addons-qt6: 1.14.1 -> 1.15.0 [FreeBSD] |
| 284 | level-zero: 1.33.1 -> 1.34.0 [FreeBSD] |
| 285 | lib2geom: 1.4_5 -> 1.4_6 [FreeBSD] |
| 286 | libcmis: 0.6.3_1 -> 0.6.3_2 [FreeBSD] |
| 287 | libfreehand: 0.1.3 -> 0.1.4 [FreeBSD] |
| 288 | libheif: 1.22.2_3 -> 1.22.2_4 [FreeBSD] |
| 289 | libixion: 0.20.0_3 -> 0.20.0_4 [FreeBSD] |
| 290 | libkml: 1.3.0_31 -> 1.3.0_32 [FreeBSD] |
| 291 | libmikmod: 3.3.13 -> 3.3.14 [FreeBSD] |
| 292 | liborcus: 0.21.0_2 -> 0.21.0_3 [FreeBSD] |
| 293 | libreoffice: 26.8.0.3_1 -> 26.8.0.3_2 [FreeBSD] |
| 294 | librewolf: 156.0 -> 157.0 [FreeBSD] |
| 295 | libslirp: 4.9.4 -> 4.9.5 [FreeBSD] |
| 296 | libtorrent-rasterbar2: 2.0.13,1 -> 2.0.13_1,1 [FreeBSD] |
| 297 | libwmf: 0.2.15 -> 0.2.16 [FreeBSD] |
| 298 | linux_libusb-rl9: 13.1.0 -> 13.1.0_1 [FreeBSD] |
| 299 | mesa-dri: 26.2.2 -> 26.2.2_1 [FreeBSD] |
| 300 | mesa-libs: 26.2.2 -> 26.2.2_1 [FreeBSD] |
| 301 | meson: 1.10.2_1,1 -> 1.12.1,1 [FreeBSD] |
| 302 | msgpack-c: 6.1.0 -> 7.0.2 [FreeBSD] |
| 303 | node24: 24.21.0 -> 24.21.0_1 [FreeBSD] |
| 304 | nss: 3.130 -> 3.131 [FreeBSD] |
| 305 | ollama: 0.34.3 -> 0.40.0 [FreeBSD] |
| 306 | opencv: 4.13.0_8 -> 4.13.0_9 [FreeBSD] |
| 307 | openexr: 3.4.15_2 -> 3.4.16 [FreeBSD] |
| 308 | openldap26-client: 2.6.15 -> 2.6.15_1 [FreeBSD] |
| 309 | p5-Authen-SASL: 2.2000 -> 2.2100 [FreeBSD] |
| 310 | p5-Image-ExifTool: 13.36 -> 13.55 [FreeBSD] |
| 311 | pciids: 20260918 -> 20260922 [FreeBSD] |
| 312 | pcre2: 10.48 -> 10.49 [FreeBSD] |
| 313 | pkgconf: 3.0.6,1 -> 3.0.7,1 [FreeBSD] |
| 314 | podman: 5.8.6_1 -> 5.8.6_2 [FreeBSD] (vulnerable!) |
| 315 | popt: 1.19_2,1 -> 1.19,2 [FreeBSD] |
| 316 | protobuf-c: 1.5.1_4 -> 1.5.2 [FreeBSD] |
| 317 | py312-boost-libs: 1.91.0 -> 1.92.0 [FreeBSD] |
| 318 | py312-dbus: 1.4.0 -> 1.4.0_1 [FreeBSD] |
| 319 | py312-nbxmpp: 7.2.0 -> 7.4.0 [FreeBSD] |
| 320 | py312-pipx: 1.17.4 -> 1.17.5 [FreeBSD] |
| 321 | py312-platformdirs: 4.11.11 -> 4.11.12 [FreeBSD] |
| 322 | py312-pycparser: 2.23 -> 3.0 [FreeBSD] |
| 323 | py312-pyparsing: 3.3.2 -> 3.3.3 [FreeBSD] |
| 324 | py312-truststore: 0.10.4 -> 0.10.4_1 [FreeBSD] |
| 325 | py312-websockets: 17.1 -> 17.2 [FreeBSD] |
| 326 | python312: 3.12.14 -> 3.12.14_1 [FreeBSD] (vulnerable!) |
| 327 | qbittorrent: 5.2.3_2 -> 5.2.4_1 [FreeBSD] |
| 328 | qca-qt6: 2.3.10_5 -> 2.3.12 [FreeBSD] |
| 329 | qemu: 11.1.1 -> 11.1.2 [FreeBSD] |
| 330 | qt5-webview: 5.15.19p0 -> 5.15.19p0_1 [FreeBSD] |
| 331 | rsync: 3.5.0_2 -> 3.5.1 [FreeBSD] |
| 332 | ruff: 0.16.8 -> 0.16.9 [FreeBSD] |
| 333 | scrcpy: 4.1 -> 5.0 [FreeBSD] |
| 334 | sfcgal: 2.3.0_1 -> 2.3.0_2 [FreeBSD] |
| 335 | shaderc: 2026.4 -> 2026.4_1 [FreeBSD] |
| 336 | simdjson: 4.6.11_1 -> 5.0.1 [FreeBSD] |
| 337 | simdutf: 9.2.0 -> 9.2.1 [FreeBSD] |
| 338 | snappy: 1.2.2 -> 1.3.1 [FreeBSD] |
| 339 | source-highlight: 3.1.9_15 -> 3.1.9_17 [FreeBSD] |
| 340 | spirv-llvm-translator-llvm19: 19.1.22 -> 19.1.23 [FreeBSD] |
| 341 | spirv-tools: 2026.3 -> 2026.4 [FreeBSD] |
| 342 | utf8proc: 2.11.3 -> 2.12.0 [FreeBSD] |
| 343 | vde2: 2.3.3.57_1 -> 2.3.3.86 [FreeBSD] |
| 344 | vulkan-headers: 1.4.360 -> 1.4.365 [FreeBSD] |
| 345 | vulkan-loader: 1.4.360 -> 1.4.365 [FreeBSD] |
| 346 | x265: 4.1 -> 4.2 [FreeBSD] |
| 347 | xfce-icons-elementary: 0.22 -> 0.23 [FreeBSD] |
| 348 | xlockmore: 5.88 -> 5.89 [FreeBSD] |
| 349 | |
| 350 | Installed packages to be REINSTALLED: |
| 351 | cyrus-sasl-2.1.28_6 [FreeBSD] (option changed: LMDB0 (added)) |
| 352 | drm-kmod-20260508 [FreeBSD] (direct dependency changed: drm-612-kmod (added), drm-66-kmod (removed)) |
| 353 | luanti-5.17.0_1 [FreeBSD] (direct dependency changed: luajit (removed), luajit-openresty (added), ncurses (removed), openssl (removed)) |
| 354 | mysql84-client-8.4.11_1 [FreeBSD] (direct dependency changed: openldap26-client (origin changed)) |
| 355 | samba416-4.16.11_12 [FreeBSD] (direct dependency changed: openldap26-client (origin changed)) |
| 356 | seahorse-47.0.1 [FreeBSD] (direct dependency changed: openldap26-client (origin changed)) |
| 357 | |
| 358 | Installed packages to be REMOVED: |
| 359 | luajit: 2.1.0.20260903 |
| 360 | luv: 1.52.1.0 |
| 361 | mpv: 0.41.0_2,1 |
| 362 | neovim: 0.12.5 |
| 363 | obs-studio: 32.2.2 |
| 364 | |
| 365 | Number of packages to be removed: 5 |
| 366 | Number of packages to be installed: 15 |
| 367 | Number of packages to be upgraded: 309 |
| 368 | Number of packages to be reinstalled: 6 |
| 369 | |
| 370 | The process will require 1 GiB more space. |
| 371 | 4 MiB to be downloaded. |
| 372 | |
| 373 | WARNING: 2 package(s) have known vulnerabilities |
| 374 | |
| 375 | Proceed with this action? [y/N]: |
swee / gistfile1.txt
Last active 1 month ago
