| 1 | #!/usr/bin/python3 |
| 2 | import os |
| 3 | from time import sleep |
| 4 | while True: |
| 5 | code = os.system("python /home/swee/sweebot.py") |
| 6 | print("Exit code: " + str(code)) |
| 7 | sleep(5) |
swee / old SweeBot source code
Modified May 16, 2024. I have no idea where the resolver code is.
| 1 | import socket |
| 2 | import sys |
| 3 | import psutil |
| 4 | import subprocess |
| 5 | import requests |
| 6 | import platform |
| 7 | import distro |
| 8 | from time import sleep |
| 9 | busy = False |
| 10 | class bot_irc: |
| 11 | |
| 12 | irc_socket = socket.socket() |
| 13 | |
| 14 | def __init__(self): |
| 15 | self.irc_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM) |
| 16 | |
| 17 | def send_irc(self, channel, msg): |
| 18 | self.irc_socket.send(bytes("PRIVMSG " + channel + " :" + msg + " \n", "UTF-8")) |
| 19 | |
| 20 | def connect_irc(self, server, port, channel, bot_nick, bot_pass, bot_nickpass): |
| 21 | print("Server connection: " + server) |
| 22 | self.irc_socket.connect((server, port)) |
| 23 | |
| 24 | self.irc_socket.send( |
| 25 | bytes( |
| 26 | "USER " + bot_nick + " " + bot_nick + " " + bot_nick + " :SweeBot, a very cool bot made by Swee :3\n", |
| 27 | "UTF-8", |
| 28 | ) |
| 29 | ) |
| 30 | self.irc_socket.send(bytes("NICK " + bot_nick + "\n", "UTF-8")) |
| 31 | self.irc_socket.send( |
| 32 | #bytes("NICKSERV IDENTIFY " + bot_nickpass + " " + bot_pass + "\n", "UTF-8") |
| 33 | bytes("PASS " + bot_nickpass + ":" + bot_pass + "\n", "UTF-8") |
| 34 | ) |
| 35 | for i in channel: |
| 36 | self.irc_socket.send(bytes("JOIN " + i + "\n", "UTF-8")) |
| 37 | |
| 38 | def response_irc(self): |
| 39 | r = self.irc_socket.recv(2040).decode("UTF-8") |
| 40 | if r.find("PING") != -1: |
| 41 | self.irc_socket.send( |
| 42 | bytes("PONG " + r.split()[1] + "\r\n", "UTF-8") |
| 43 | ) |
| 44 | return r |
| 45 | |
| 46 | server_irc = "127.0.0.1" |
| 47 | port_irc = 5000 |
| 48 | channels = ["##sweezero","##","##rudechat","##mintHTML","##elysium","##gnu/crack"] |
| 49 | botnick_irc = "sweeBot" |
| 50 | botnickpass_irc = "sweeBot" |
| 51 | botpass_irc = "swee15cool" |
| 52 | irc = bot_irc() |
| 53 | irc.connect_irc( |
| 54 | server_irc, port_irc, channels, botnick_irc, botpass_irc, botnickpass_irc |
| 55 | ) |
| 56 | re = "http://192.168.12.225:1337/" |
| 57 | def rA(): |
| 58 | try: |
| 59 | requests.get(re + "os") |
| 60 | return True |
| 61 | except: |
| 62 | return False |
| 63 | while True: |
| 64 | text = irc.response_irc() |
| 65 | try: |
| 66 | channel_irc = str(text).split(" ")[2] |
| 67 | except: |
| 68 | continue |
| 69 | command = str(text).split(":") |
| 70 | command = command[len(command) - 1][:-2].split(" ") |
| 71 | try: |
| 72 | print(text) |
| 73 | except: |
| 74 | print("Unable to print text, possible unicode?") |
| 75 | if command[0] == "": |
| 76 | continue |
| 77 | if "PRIVMSG" in text and channel_irc in channels and command[0][0] == "$": |
| 78 | |
| 79 | username = str(text).split(" ")[0].split("@")[1] |
| 80 | nick = str(text).split(" ")[0].split("@")[0][1:].split("!")[0] |
| 81 | print(command) |
| 82 | if not busy: |
| 83 | busy = True |
| 84 | if command[0] == "$hello": |
| 85 | if rA(): |
| 86 | irc.send_irc(channel_irc, "Greetings " + nick + ", I am SweeBot!") |
| 87 | else: |
| 88 | irc.send_irc(channel_irc, "Hey " + nick + ", have you seen my resolver? *pulls out picture of a Raspberry Pi 3*") |
| 89 | |
| 90 | elif command[0] == "$cpu": |
| 91 | irc.send_irc(channel_irc, "The core bot is using " + str(int(psutil.cpu_percent())) + "% of its CPU right now.") |
| 92 | if rA(): |
| 93 | exec(requests.get(re + "cpu").content) |
| 94 | else: |
| 95 | irc.send_irc(channel_irc, "And it would be different if it were for my little ARM friend, the resolver. T_T") |
| 96 | |
| 97 | elif command[0] == "$ram": |
| 98 | irc.send_irc(channel_irc, "The core bot is using " + str(int(psutil.virtual_memory().percent)) + "% of its RAM right now, which is " + str(int(psutil.virtual_memory().used/1024/1024)) + "MB of 2GB") |
| 99 | if rA(): |
| 100 | exec(requests.get(re + "ram").content) |
| 101 | else: |
| 102 | irc.send_irc(channel_irc, "where's my resolver?! T_T") |
| 103 | |
| 104 | elif command[0] == "$os": |
| 105 | irc.send_irc(channel_irc, "Core bot: " + distro.name() + " " + distro.version() + " running on " + platform.node()) |
| 106 | if rA(): |
| 107 | exec(requests.get(re + "os").content) |
| 108 | else: |
| 109 | irc.send_irc(channel_irc, "And I'm lonely because my resolver is gone... T_T") |
| 110 | |
| 111 | elif command[0] == "$ping": |
| 112 | if rA(): |
| 113 | irc.send_irc(channel_irc, nick + ": Pong") |
| 114 | else: |
| 115 | irc.send_irc(channel_irc, nick + ": P- P- Pong... *sobs*") |
| 116 | |
| 117 | elif command[0] == "$channel": |
| 118 | irc.send_irc(channel_irc, nick + ": I'm currently chatting on " + channel_irc + " which is one of my " + str(len(channels)) + " channels I'm currently configured with.") |
| 119 | elif command[0] == "$command": |
| 120 | perms = requests.get(re + "admin/getperm?user=\"" + username + "\"").content.decode().split(",") |
| 121 | print(perms) |
| 122 | if len(command) > 1: |
| 123 | if "full" in perms or "command" in perms: |
| 124 | cmd = command[1:] |
| 125 | cmd2 = "" |
| 126 | for i in cmd: |
| 127 | cmd2+=i+" " |
| 128 | irc.irc_socket.send(bytes(cmd2 + "\n", "UTF-8")) |
| 129 | irc.send_irc(channel_irc, nick + ": Sent to server.") |
| 130 | else: |
| 131 | irc.send_irc(channel_irc, nick + ": Permission denied.") |
| 132 | else: |
| 133 | irc.send_irc(channel_irc, nick + ": Why no command?") |
| 134 | |
| 135 | else: |
| 136 | print(re + command[0][1:]) |
| 137 | if rA(): |
| 138 | try: |
| 139 | exec(requests.get(re + command[0][1:] + "?nick=" + nick + "&user=\"" + username + "\"").content) |
| 140 | except: |
| 141 | irc.send_irc(channel_irc, "unrecognized command or resolver ran into an error.") |
| 142 | else: |
| 143 | irc.send_irc(channel_irc, "Sorry, I can't do anything anymore without my one and only re- re- resolver. *sobs*") |
| 144 | busy = False |
| 145 | else: |
| 146 | irc.send_irc(channel_irc, "DUDE I'M BUSY.") |
